C5-2003 memory select problem
Old Mar 9, 2020 | 06:40 PM
Herb Clore's Avatar
Herb Clore
1st Gear
Default C5-2003 memory select problem
My memory selector is not allowing seat adjustment, steering wheel adjustment or mirror adjustments. I can adjust the mirrors from the mirror buttons. I can move the seat and steering wheel using switch when not seated or lifting my butt from the seat. All positions reset when car is locked or a large amount of time has passed once engine is off. Any help troubleshooting will be much appreciated.
Old Mar 9, 2020 | 06:44 PM
tommyallen's Avatar
tommyallen
Sounds like you need a new battery. Check your voltage with a meter.
Old Mar 12, 2020 | 07:59 AM
ncali's Avatar
ncali
My seat (drivers side ) is also doing something similar to yours . The memory on mine works but I cannot adjust the seat forward or backwards when I am sitting in the seat. I get out of the car and all functions work like they should I have my seat adjusted almost all the way back and im thinking it fits tight in its position.
Sounds like Bill Curlee or Evil Twin could help out
Old Mar 12, 2020 | 01:14 PM
Karate Kid's Avatar
Karate Kid
Default Seat Memory
My 2003 has been having a problem with the seat memory.
Sometimes it works, sometimes it doesn't.
Sometimes when I try to manually move it forward it will only move in very short amounts (less than an inch).
Old Mar 12, 2020 | 04:14 PM
ncali's Avatar
ncali
try moving the seat when you are not sitting in it
To C5-2003 memory select problem
