Proper location for this ground?
Old Mar 11, 2020 | 02:35 PM
Cory51191's Avatar
Cory51191
Default Proper location for this ground?
While I’m in here... this was bolted to the back of the passenger side head. Where is the proper grounding location?!
thanks!
Old Mar 11, 2020 | 02:47 PM
v6turbo87's Avatar
v6turbo87
What makes you think it isn't supposed to be bolted to the head?
Old Mar 11, 2020 | 03:22 PM
robmiz's Avatar
robmiz
I believe that the ground wire for TAC module. It bolted to same ground as the negative side of battery on the engine block, just above the starter.
Old Mar 11, 2020 | 03:37 PM
Cory51191's Avatar
Cory51191
As far as I’m aware there is nothing grounded to the back of the passenger side head.
Old Mar 11, 2020 | 04:58 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
CORRECT !!...no ground located on the passenger side head...the ground for both bank coil packs located on drivers side head (G107). Is it a black or black/white wire ??
Old Mar 11, 2020 | 05:02 PM
helga203's Avatar
helga203
Zoom in looks blk and wh
Old Mar 11, 2020 | 05:57 PM
C6Z_LS7's Avatar
C6Z_LS7
correct. Just went through it a few weeks go. I took a picture so I wouldn’t lose where everything went. luckily I kept it....
Old Mar 11, 2020 | 06:32 PM
Cory51191's Avatar
Cory51191
It is black and white and looks identical to the coil ground, but that ground is in fact bolted to the back of the driver side head.
Still unsure what this one goes to.
Old Mar 11, 2020 | 06:40 PM
StingrayRebel's Avatar
StingrayRebel
that could also be a ground for one of the fan relays, there are a few in the same location that look similar so as long as you get it grounded the location isn't really important... you can see the stud it was originally grounded to in the upper left of your pic on top of the frame rail
Old Mar 11, 2020 | 06:46 PM
Cory51191's Avatar
Cory51191
I just took another look at it and it appears to have the same wires attached to my starter..
This mystery wire comes out of the same portion of the harness as the smaller starter wires come from.. here’s another pic!
Old Mar 11, 2020 | 07:08 PM
C5 Diag's Avatar
C5 Diag
This is G104 I believe and it’s below the battery negative terminal..there are 3 wires that are attached to the stud. I forget what this ground applies to !!
Old Mar 11, 2020 | 07:14 PM
Cory51191's Avatar
Cory51191
Thats where I thought it should go but the eye is much larger than the stud. Either way, that’s where it’s going. Also why does yours have a plate on it? Mine is just a stud with a nut.
Old Mar 11, 2020 | 07:20 PM
C5 Diag's Avatar
C5 Diag
It is just a little flap that covers the stud...yours may just be missing !!...there are also a few ground wires where the negative cable of the battery attaches to at the engine block...it may go there...that eye is larger there !!
Old Mar 11, 2020 | 07:38 PM
Cory51191's Avatar
Cory51191
Unfortunately it doesn’t reach that one.
I’ll put it on the frame stud, thank you!!
To Proper location for this ground?
