Now What?!!
Old Nov 21, 2002 | 02:36 PM
scool93535's Avatar
scool93535
Default Now What?!!
Last night I intended to turn on the fog lights only and the head lamps popped up. :confused: The headlamps were off but the assembly popped up as if the headlights were on. Previously I could just use the fog lamps without the headlamps popping up? :confused:
Add to that when I turned the lights off, the headlamps went down and the driver side makes a loud rapid wratching noise for a few seconds? :cuss
Ok so I figure I need to replace the motor but, what's that got to do with both lamps popping up when you turn on the parking lights and have the fog lights on? :smash: :smash:
It's these small little :bs things that the ricer manufacturers don't make their customers put up with. :cuss
Does anyone agree I need to replace the headlamp drive motor or is there something else I should checkout first?
Thanks. :cheers:
