Transmission won't shift
Old Mar 21, 2020 | 01:27 PM
Paulo Cabral's Avatar
Paulo Cabral
4th Gear
Default Transmission won't shift
Transmission wouldnt shift and just let the rpm raise so i figured just put a new transmission. Put in a transmission with 60k miles and for the first 40 miles it ran fine but now it does the same thing. Shifts from 1 to 2 sometimes to 3 but after that it wont shift only raise the rpms. Any help would be much appreciated.
Old Mar 21, 2020 | 05:13 PM
feeder82's Avatar
feeder82
I don't know much about autos, but have you checked for codes? It could be the 3-4 clutches have burnt out, possibly the shift solenoids have failed
Old Mar 21, 2020 | 05:45 PM
bonesbrakr's Avatar
bonesbrakr
We will presume you filled it properly. Did you flush the lines to clean out the old fluid? My thinking is the cooler lines are clogged or the rad cooler and reduced fluid flow thereby burning up the trans. Condition of fluid??? Brownish red or burnt smell???
To Transmission won't shift
