Just bought a 99 with 38k.......
Old Nov 21, 2002 | 10:41 PM
Roadshadow's Avatar
Roadshadow
Default Just bought a 99 with 38k.......
This car appears to be well taken care of. Needs rear tires so I'll fix that with four new skins.
Here's the question, what would you seasoned owners do first off?
I'll get the oil and filter changed asap.
How long do stock brake pads last.
Should I go ahead and change plugs and wires?
Any thoughts would be appreicated.
Old Nov 21, 2002 | 11:15 PM
Golf Man's Avatar
Golf Man
Default Re: Just bought a 99 with 38k....... (Roadshadow)
Congrads on the new ride. If you are not aware of the maintenance history of vehicle twist an arm at your local dealer and have him pull up the computer history. It will give you an idea of the past repairs and milage along with any recalls missed. I have had my 99 for 1 1/2 and lovin every minute of it. :cheers:
Old Nov 22, 2002 | 08:10 AM
TOPGUN9's Avatar
TOPGUN9
I've had my '99 since new. Trust me. You'll love this car! Life of the brakes depend soley on how the car was driven. At 38,000, you better check them out. If the plugs are original, it's time for new ones and new wires. If the battery is the original Delco, I would consider replacing it with an Optima. The original batteries had a tendency to leak, and take out the computer underneath it. Bad news if this happens! Enjoy your new ride.
Old Nov 22, 2002 | 08:26 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Re: Just bought a 99 with 38k....... (TOPGUN9)
If you don't have a maintenace record dump all the fluids, engine, tranny, rear, brake, and coolent may be due now too. Brakes are easy to check just pull the wheels. Check tire wear for alignment if required. Check tire pressures. enjoy it's the best year made :D
Old Nov 22, 2002 | 08:36 AM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Brake pads can last a long time. My original pads are only 50% gone at 40,000 miles. Obviously, I do a lot of highway driving.
Old Nov 22, 2002 | 08:53 AM
90 droptop's Avatar
90 droptop
Default Re: Just bought a 99 with 38k....... (John Shiels)
Plus I would get rid of the Delco battery, they leak. Do the plugs and wires, get a good intake, a nice cat-back system.....oooppppps, getting carried away.
Old Nov 22, 2002 | 06:54 PM
topgun's Avatar
topgun
Congrats on your '99!!!
Change oil and filter (Mobil 1 Synthetic 5/30 is factory recommended)
Be very careful with oil drain plug (pan is aluminum)
Replace spark plugs.
Check fluids: Coolant, Trans, Diff, Power Steering, Brake, Clutch.
Check Air Filter
Check Brake and Tire wear.
Check Serp Belt.
Enjoy the ride!!! :yesnod: :yesnod: :yesnod:
PS Be very careful of the forum...its addictive and can lead to a light wallet. :eek: :eek: :eek: :eek:
Old Nov 22, 2002 | 07:58 PM
Old Rotor Head's Avatar
Old Rotor Head
:cheers:
Oil every 3k (Mobile 1)
Air Filter 15K
Plugs/wires 25k
Tires prn
Brake pads still have 50% at 31k+
Old Nov 23, 2002 | 05:44 AM
99inDenver's Avatar
99inDenver
Congrats on the 99, got mine about 3 months ago and still have the same smile on my face that you probably have now.
Here is what I did
Oil Change (Mobile 1)
Change Fluids (Dif, Tranny, Steering, Coolant)
Replaced the Air filter with K&N replacement (will get a Blackwing soon)
Look at your battery and if it is the stock one, pull it out and put something else in, the consensus here is the AC Delco AGM (glass mat) or one of the Optima batteries. The reason for this is that the stock batteries will develop a leak around the positive terminal and cause mass damage to the PCM located directly under the battery.
I just had all 4 rotors turned and the front pads replaced at 28K, cost me $250 at my GM dealer
Check with the dealer and see if the column lock recall has been performed on your car. If it’s an automatic its really easy to check, with the car off and the key out of the ignition, try to turn the steering wheel, if it turns your golden. If it does not then you may want to get the recall performed or by the bypass kit from the forum mall. If you have a MN6, I’m not too sure how to check to see if the recall has been performed.
Other than that, if you are planning on spending any time here at the forum (and I think you will :yesnod: ), pick up some Zaino and a Blackwing, they seem to be requirements :jester
and one more thing........PICS.
:cheers:
enjoy the car.
[Modified by 99inDenver, 3:44 AM 11/23/2002]
Old Nov 23, 2002 | 09:02 AM
Crushinator's Avatar
Crushinator
Default Re: Just bought a 99 with 38k....... (99inDenver)
Excellent advice so far! Congrats on the new ride! :cool: :cheers:
Old Nov 23, 2002 | 07:58 PM
sgm's Avatar
sgm
Drive it like you stold it. Congrats... :smash:
To Just bought a 99 with 38k.......
