Have a loud "hissing" noise coming from engine bay. Sounds almost like pressurized air being let out of something or pushed through something. What do you think it could be?
Here is the video:
https://youtu.be/kgTgcF8dz_o
Does this occur just after engine start up and continue for about 30-45 seconds ???...may just be your AIR pump running !!...if not maybe a vacuum leak...a little difficult to diagnose from this end !!
that video was after driving about 3-4 miles and driving in city for 10 minutes. How could I diagnose better?
Sprayed all around the intake manifold and vacuum lines today with some MAF cleaner and didn't notice any change in the revs. Did notice that the sound seems like it could possibly be from the fuel line and I can feel the pressure of the fuel moving in somewhat tandem with the sound. Could it possibly just be this? I don't smell gas or see any leaks from this line
i would recommend you take the car to a mechanic. These posts are all over the place. Ac fan, ac cool, hissing, spraying maf cleaner, fuel pressure. No offense, but you don’t sound mechanically inclined. Get the car to a tech for the safety of you and the car.
the ac issue is because the ac belt slipped off. Likely due to the fact that some dexcool leaked onto the ac pulley and belt a little belt. AC issue solved. Coolant levels not low and I have identified source of the leak. Hissing sound TBD. MAF test is pretty basic stuff to help identify vacuum leak albeit not the most effective. Posts not really all over the place just facts that may connect two symptoms that another person has experienced that could lead to a good recommendation. Pretty simple stuff really. I have 2 likely ideas as to source of hiss now and should have it fixed by tomorrow. I'll update the results so that anyone going forward may benefit.
Did you run it with the belt off? The video is really hard to watch and hear, but it doesn't look like the tensioner deflects at all. It could be as simple as a bad pulley bearing.
