CCW Drag wheel owners...
Old Nov 22, 2002 | 10:21 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default CCW Drag wheel owners...
What is the size and back spacing of your rear rims? Did you have to grind your suspension to have them fit?
Old Nov 22, 2002 | 02:47 PM
ApeelinC5's Avatar
ApeelinC5
Default Re: CCW Drag wheel owners... (ICULUKN-C5)
I don't have this package yet, but know people w/ them. There is a little grinding required. It is Very Very minimal though.
Old Nov 22, 2002 | 07:02 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: CCW Drag wheel owners... (ApeelinC5)
ttt
Old Nov 22, 2002 | 07:16 PM
bruce1's Avatar
bruce1
The grinding is min....... just enough to make you work.....
Old Nov 22, 2002 | 11:29 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: CCW Drag wheel owners... (bruce1)
I have the 335's on 18x11 rims and I did not have to grind anything. there is about 1/4 inch to the upper a-arm though. Very tight but an excellent fit. Call John, he will set you up with the right combo. :seeya
Old Nov 22, 2002 | 11:55 PM
Redline Motorsports's Avatar
Redline Motorsports
Default Re: CCW Drag wheel owners... (CHRIS NJ C5)
I have the standard CCWDrag setup and only had to peen down the upper ball joint dust cover to make them work.
Old Nov 23, 2002 | 02:05 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: CCW Drag wheel owners... (9D9LS1)
what do you mean 'peen'? Did you hit it with a ball peen hammer?
With the stock Firebird rims that I have. I think I have to grind the top of the bolt.
Old Nov 24, 2002 | 03:44 AM
ZO6Bill's Avatar
ZO6Bill
I have the CCW drag pac wheels, I had to take a file and take off the little bump on top of the ball joint to make the rims fit. use a hand grinder or what ever. :D It's not a BIG DEAL to remove that little bit. :flag :seeya
Old Nov 24, 2002 | 04:43 PM
C5_PIG's Avatar
C5_PIG
Default Re: CCW Drag wheel owners... (ZO6Bill)
A little grinding had to be done on part of suspension. Call John at CCW and he will hook you up with the same setup most have. Again the grinding is minimal.
Old Nov 24, 2002 | 06:29 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
If you did the grinding you had to do for the firebird rims you will be fine for the CCW's
To CCW Drag wheel owners...
