Cylinder 7 noise
Old Mar 30, 2020 | 12:43 PM
bwill03z's Avatar
bwill03z
Default Cylinder 7 noise
I have an excessive ticking noise on the driver side that sounds like it’s coming from cylinder 7. It’s not crazy loud but def louder than the passenger side and is very annoying. I’ve pulled the valve covers several times and everything looks fine. I have a 228/228 .600 cam, dual springs and ls7 lifters with less than 2k miles on it since the work. Is there anything in particular that would affect cylinder 7 more than the others? I have no misfires, oil pressure is okay and it runs fine. When hot the oil pressure can get down to about 30psi but is good otherwise. It’s annoying as hell when driving, it’s especially noticeable around 1500-2000rpms.
Old Mar 30, 2020 | 04:16 PM
Cutlassmaster's Avatar
Cutlassmaster
Have you recently taken compression readings from the cylinders?
Old Mar 30, 2020 | 04:24 PM
aaronc7's Avatar
aaronc7
My car had a light ticking sound at idle/low rpm when I cracked the piston and cylinder liner....otherwise ran good enough you wouldn't know it lol. I thought it was valvetrain until I did a compression test and pulled the smashed spark plug. Not trying to scare you or anything but a quick spark plug check might not be a bad idea.
Old Mar 30, 2020 | 06:17 PM
bwill03z's Avatar
bwill03z
No I haven’t
I can go pull the plug and post a pic
Old Mar 30, 2020 | 08:26 PM
DBS99MagRedCoupe's Avatar
DBS99MagRedCoupe
Exhaust leak?
Old Mar 30, 2020 | 08:44 PM
bwill03z's Avatar
bwill03z
Originally Posted by DBS99MagRedCoupe
Exhaust leak?
I wish but I’ve pretty much ruled that out
Old Mar 30, 2020 | 09:38 PM
aaronc7's Avatar
aaronc7
Video would be good, I assume the noise gets faster with higher rpm?
Old Mar 30, 2020 | 10:32 PM
bwill03z's Avatar
bwill03z
Yeah it does follow rpm’s and really stands out around 1200-1800 rpm’s. I’ll post a good video tomorrow
Old Mar 31, 2020 | 08:44 AM
dskinsler83's Avatar
dskinsler83
Hopefully its not a lifter about to go out like mine did!
Do you have coolant crossovers in the rear? Isnt Cylinder 7 the one that gets the piston problem??
Old Mar 31, 2020 | 09:50 AM
bwill03z's Avatar
bwill03z
My driver side has always been a bit noisier than the passenger side for some reason but nothing crazy, even when the motor was stock. I believe I have read that cylinder 7 is the one most prone to piston trouble and that’s why I am concerned. I’ll post a video and see what u guys think
Old Mar 31, 2020 | 11:04 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Old Mar 31, 2020 | 11:15 AM
bwill03z's Avatar
bwill03z
Here’s a video of what I’m talking about, I’ll post a better one later. Again, everything looks good under the valve cover. Before everyone says pushrod length I’ve measured and I’m running the correct lifter preload and just to be sure I’ve even tested out three different length of pushrods, no change. Is this normal?
Old Mar 31, 2020 | 01:55 PM
tabbruzz's Avatar
tabbruzz
piston slap??
Old Mar 31, 2020 | 04:09 PM
bwill03z's Avatar
bwill03z
Originally Posted by tabbruzz
piston slap??
Not piston slap. I’m aware of it, every LS car I’ve owned has had it to some degree but this def isn’t that.
Old Mar 31, 2020 | 04:28 PM
tabbruzz's Avatar
tabbruzz
Well, glad to hear....hopefully something cheap and easy.....I know sometimes the injectors can be noisy but yours sounds a bit too loud....what about exhaust gasket leak or manifold\heard bolt loose.....Ahh, just looking at the cheap and easy stuff
Old Mar 31, 2020 | 04:36 PM
bwill03z's Avatar
bwill03z
A cheap and easy fix would be great but unfortunately I’m not that lucky lol. I’ve checked for exhaust leaks, loose bolts, everything. I’ve seen other videos of cammed motors that sounds similar so Idk maybe this is normal? But something tells me it isn’t... I know there’s a lot of cammed cars on here so I was hoping somebody could enlighten me. All I can figure is that it’s lifter or piston related. The lifters are brand new ls7 lifters so idk...
Old Mar 31, 2020 | 06:55 PM
aaronc7's Avatar
aaronc7
Get another video at a constant engine speed (idle), and put the camera in a spot where it can pick up audio well and get at least a 5 second clip. You can slow the video down and count the taps to see if its something thats happening once per crank revolution or once per cam revolution (half crank rpm). That should help you narrow down whether it's a piston noise or something in the valvetrain. I think it sounds like valvetrain (half speed) but video to confirm is good.
To Cylinder 7 noise
Old Mar 31, 2020 | 08:03 PM
dskinsler83
Sounds like a lifter brother
Old Mar 31, 2020 | 08:19 PM
bwill03z's Avatar
bwill03z
So when the motor was stock I felt like it was a little noisier than most and after the cam swap and new lifters it sounds like this. I’m wondering if maybe I have something going on with my oil pump such as the o-ring pinched or something. I remember seeing a thread where a guy had a pinched o-ring but normal oil pressure and it was letting air get in the lifters and causing them to be noisy. When I had my cam done I just kept the stock oil pump. I feel like it’s related to the lifters also.
Old Apr 1, 2020 | 12:16 AM
StingrayRebel's Avatar
StingrayRebel
make sure it isn't the evap solenoid, my old trans am made a similar noise and it ended up being that solenoid... it's on the same side you are hearing the noise and is easy to check, just put the tip of a long screwdriver against it and the handle against your ear... actually you can use that same screwdriver trick to isolate the location of the noise if it doesn't end up being the solenoid
