low temp therm
Old Nov 22, 2002 | 12:49 PM
skidmarc's Avatar
skidmarc
Default low temp therm
Is it worth putting in low temp thermostat? If so which one do you guys recommend?
Do I need to put in fan switch or reprogram computer to turn fan on earlier for it to be beneficial or will the low temp therm do justice on its own???
Thanks Guys
Old Nov 22, 2002 | 01:13 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Default Re: low temp therm (skidmarc)
It's worth it, I'll be installing one as soon as I decide on what I'll be using to program my fans (LS1 edit, Predator).
you will either need a fan switch or reprogram to take advantage of the lower temp thermostat. :cheers:
