Grizzly header system better than FLPs?
http://www.store.yahoo.com/zipproduc...ullenhead.html
Looks like an alternative to the FLPs! What do you think? :)
"The Grizzly has produced excellent horsepower gains of up to 50 HP and torque gains of up to 60 ft/lbs."
I say :bs :yesnod:
Still a pricey setup, but sure looks nice. The hp and tq figures look seriously bloated, and I would love to see someone install the entire system in 2.5 hrs. :rolleyes:
:cheers:
1. all stainless steel
2. band clamps
3. looks like they made a better attempt at developing a true 'equal length' header.
If you have the dough, get them. dont get yer hopes up on their advertised gains, however, you will be pleased nontheless. I got 25rwhp/30rwtq with the FLPs. The Grizzly design looks a lot closer to equal length, which will greatly aid in exhaust harmonics, which will bump power more, of course.
[Modified by rwj383, 11:59 PM 11/22/2002]
I've just spent two days at Lou's shop. Everything he says about his work is absolutely true. He's trying to provide the C5 community with race quality work adapted to modified and highly modified street cars. The time and hand work involved in fabricating parts of this quality is substantial, hence the price.
As always, you get what you pay for.
I just want to point out that LGs, SLPs, etc. are no real alternatives to the two systems mentioned above. :nono:
Of course it's (as always) a question what you're looking for! :)
Here's my personal comparison of the three non-weld header systems:
SLP's system is not sold as a total package. You need to combine headers, installation kit, downpipe, hi-flow cats and X-pipe/resonator. Everything together costs just under $1,900. Only the headers are ceramic coated, the rest isn't. Everything is made of stainless steel though. I think there are too many separate parts you have to combine, resulting in too many connections. Positive: the connections are slip-fit and don't use V-clamps.
FLP's system is made of mild steel and is fully coated, except for the cats which are of uncoated stainless steel. Price is less than $1,600. It's relatively easy to exchange the hi-flow cats for the supplied off-road pipes, made possible by the use of V-clamps. These can cause exhaust leaks if not seated properly. Excellent value for the money, great performance gains!
Grizzlys are quite expensive at $2,250. The system is completely Jet-Hot coated and made of stainless steel. The number of connections (slip-fit) is greatly reduced, band-clamps are used. Straight forward technical design without any gimmicks. Installation time should be relatively short because of this. No realworld experiences concerning fit, finish and performance gains yet. :nonod:
:seeya
[Modified by CR555, 7:19 PM 11/28/2002]
50 hp :bs 2.5 hrs install :bs
I just installed a set of long tubes....5 hours later I was done. Headers takes about 45 min. it was bolting everything back up that takes a while
