I do not feel they add anything other than skewing your PCM's interpretation of how much air is coming into the engine and then causing improper air/fuel decisions.
On a second note, I have a set of the BPP Air Foil Nylon MAF ends sitting in my garage if you want a good deal on them!
I hear they help by increasing airflow and leaning the car out for more HP,
also I have some ported nylon MAF ends for sale and a MAT sensor all for $65 plus shipping
thanks
Re: MAF Ends, Do they reallyhelp? (99 torch red vette)
Consider them sold. Email me at supervetteracer@cs.com and tell me the best way to pay you etc..
BTW: Why you, did you want to get rid of them? :confused:
Hi: I fooled around with MAF ends, and a GMS ported MAF too. Car ran best with stock MAF, no screen, and a mild clean-up (Porting/Polishing of the stock unit). JMHO :) :) :)
I took out the screen and cut the air foils out then carefully blended the step left where the screen was. Ran the car for PCM relearn and did a scan. LTRIM's were lean. Had to correct by 9% with LS1 Edit to get the curve back where I wanted it. After another relearn, car runs great with NO problems.
If you have a hacksaw and some sandpaper, you can port and polish your own MAF ends. It's much cheaper that way! I did it with mine. Best tool you could ever have for this job is an air dye. If you have an air compressor get yourself one of these! $50.00 and it grinds down all kinds of metals. Saves lots of time and energy as opposed to sanding down what you can't cut with the hacksaw. Check out this site for instructions: http://installuniversity.com/install...afapalooza.htm
