Delete F45 Question
Old Apr 7, 2020 | 02:17 PM
Sean_emory's Avatar
Sean_emory
Default Delete F45 Question
Going to install new shocks next week. Won’t have access to Tech2 to delete program from computer system for about 1 month.
I just want to make sure it’s no problem to do the shocks first before I delete the program. I know the error messages will pop up and car will be restricted to 80 MPH. But once I delete the F45 it won’t matter that I did the shocks first? I’ll be free and clear?
Old Apr 7, 2020 | 04:26 PM
StickTail's Avatar
StickTail
I believe you can put a resistor to jumper the wires you remove from the shock, this will avoid any codes. Search in tech section for F45.
Old Apr 7, 2020 | 05:00 PM
Sean_emory's Avatar
Sean_emory
Thanks, but I have a friend of a friend who is a Corvette tech and has access to the Tech2. Just asking if it will cause me any headache to do the shocks before I delete the program.
Old Apr 7, 2020 | 07:51 PM
c5capcity's Avatar
c5capcity
It will cause problems if you unplug any part of that circuit. I popped the sensor out of the old shocks, wrapped them with electrical tape and ziptied them up in the wheel well when I did my coilovers. It was meant to be temporary like yours but I never got around to a tech2 and left it like that for a couple of years.
Old Apr 7, 2020 | 09:03 PM
Notover's Avatar
Notover
No problems. I installed my shocks and drove for a week before I could get the delete done by the dealer.
Old Apr 8, 2020 | 10:14 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
You'll be free and clear !!...in case your friend hasn't done the delete I did one on YouTube a while back !!
Old Apr 9, 2020 | 02:27 AM
Moved to C5 Tech.
To Delete F45 Question
