I brought my car and a lot of work was done to motor is there a way to pull lifter and find what the size is to replace all of them or should i just swap cam and lifter i believe it happened from oil pump being at minimum specs for ls motor so should i just replace cam while in there replacing oil pump
Yes. Remove intake, valley plate, and heads, then you can remove a lifter...
Did you get an aftermarket cam ? No need to replace then. It could be aftermarket valve springs and/or lifters that are making more noise..
Talk to a good vendor about replacement lifters, there are some very good ones to replace your stock ones with...if you so choose to open up the motor just to replace lifters
After market heads after market cam any more other then that i dont know as all the work was done by previous owner i had a mechanic look it over and his reply was it might be better to replce motoback to stock which told me one of 2 thing didnt want to do work or just wanted my motor
Its a after market cam had mechanic take a look and said the motor had some money dumped into it just want to replace lifters justt want to make sure i can find correct size if it has a big cam in it
