Noise from gas line?
Old Apr 7, 2020 | 09:13 PM
Bstan1009's Avatar
Bstan1009
Default Noise from gas line?
Is there supposed to be an audible sound coming from the gas line? I can hear a slight hiss that seems to correspond with the fuel being pushed through the fuel line. When I touch the line I can feel the pressure from the gas moving and it seems to coincide with the noise but I am unsure of this is an issue and/or if it is even for sure the cause. I first assumed a vaccum line leak/break but have yet to find any. Pcv valve is all good and secure. Just recently successfully reset the hvac acuator and that code has been removed which may have been causing the hissing noise before and now I am just hearing the gas line. Any help is greatly appreciated. Thanks
