Harmonic balancer/crank pulley
Old Apr 8, 2020 | 11:20 AM
OregonDan's Avatar
OregonDan
Default Harmonic balancer/crank pulley
I can't find the previous thread I was reading. Can someone please tell me what our favored balancer/crank pulley is for street use? Thanks!!
Old Apr 8, 2020 | 11:34 AM
v6turbo87's Avatar
v6turbo87
This is one good option, Powerbond:
https://www.summitracing.com/parts/p...model/corvette
Old Apr 8, 2020 | 12:18 PM
MAVetteGuy's Avatar
MAVetteGuy
Cant beat the quality of an ATI Super Damper, plus they're rebuild-able if you plan to hang onto the car for a while.. Whatever you decide to get make sure you pin the crank. My OEM balancer spun on the crank to the point were i almost had to junk the crank when i rebuilt the engine.
Old Apr 8, 2020 | 01:18 PM
Ed Ramberger's Avatar
Ed Ramberger
Dayco Powerbond is great for for street.
Old Apr 8, 2020 | 01:34 PM
Speedy007's Avatar
Speedy007
Ati is definitely a good balancer / I used a trick flow hand forged 18.1 sfi rated . Ati was my 1st choice . The pulley from AA corvette was better priced with the same rating ! I would assume ati also has a slot to pin the crank if need to be lots of balancer out there the choices. Opinion pick up the right pulley set up for your car . I also used the stock size pulley !
Old Apr 8, 2020 | 02:27 PM
493lszosix's Avatar
493lszosix
Powerbond is fine for street/track
Old Apr 8, 2020 | 02:38 PM
Josephu's Avatar
Josephu
Powerbond/Dayco PB 1117N-SS-Race. Summit or Jegs.....around $270.
Old Apr 9, 2020 | 08:38 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I agree.....
To Harmonic balancer/crank pulley
