Clutch Drag? Hard shifting reverse/1st
There have been a number of things I've done attempting to alleviate this problem. This list is chronological:
- C6 upper shifter (better-looking ****, also in case my old shifter was worn. Used the pin to align it)
- TMOD Customs lower shifter box (frankly my old box didn't feel that sloppy. Unfortunately this lost the pin alignment feature)
- lightly used MGW C6 shifter with lower box (shorter throw, also tighter than stock C6 shifter. Made a replica of MGW's alignment tool and aligned shifter with that)
- Anti-venom mod with one washer (hoped it would reduce effort for reverse/5th/6th)
- Reverse lockout solenoid replaced (in case old one was sticking, causing difficulty accessing reverse)
- Reverse lockout solenoid spring replaced with a softer spring from Core Shifters (to reduce reverse gate effort)
- Transmission fluid drain/refill with Amsoil Torque Drive (in case old/bad fluid caused hard shifting)
- Katech remote clutch bleeder (to ease clutch fluid bleeding)
- Clutch system fluid bleed (to get out any air. Old fluid was pretty dark)
- Tick Master Cylinder installed, and adjusted to max throw where starter switch will still engage (also bled clutch system again)
Additional symptom: pretty regularly if the car is stopped, I depress the clutch pedal and put it in 1st, and the car "lurches" an inch. Almost as though the clutch is dragging enough and the transmission has to move just enough for first gear to engage.
This has led me to think the clutch simply isn't disengaging enough... clutch looked fine when the inspection cover was off, but I'm kicking myself for not having my wife press the pedal while I watch the clutch actuation.
These are the next steps I'm considering. The first two are nearly free, so fingers crossed on those:
- play around with the fore/aft placement of the shift linkage on the shifter rod (I read this can make a difference)
- again pull off the midpipe, tunnel plate, and clutch inspection cover. Mark the current SAC mechanism location and then reset it (in case the clutch drag is simply due to an over-adjusted SAC) BTW here is a guide which includes in-car SAC reset: https://paceperformance.com/files/pdf/zo6clutchadj.pdf
- if SAC mechanism sets back to the same spot, strongly consider clutch/slave cylinder/torque tube job and all that is associated
- do something with the transmission synchros while the trans is off???
Thanks for reading!
I was hoping to get under the car today but that doesn't look promising. My in-laws want to come over for Easter (tomorrow) and it sounds like we will practice some form of social distancing in the garage... where the Z06 presently resides. (my other car is also down right now, so it's not moving)
https://photos.app.goo.gl/VMeaiETjH4pwdSdq5
Do worn synchros also result in the car lurching when going into gear with the clutch pedal fully depressed?
Right, clutch isn't slipping. But there is the potential for the opposite to be true... a clutch that doesn't fully disengage, due to a over-set SAC mechanism. Alternatively, other parts can be bad: pilot bearing, throwout bearing, slave cylinder.
Had my wife press the clutch pedal while I watched what was going on. My plan was to rotate the SAC mechanism into the "reset" position with the clutch disengaged, then release the pedal, and press the pedal again to see where it would reposition itself to.
Unfortunately I couldn't get the SAC plate to rotate at all. I was concerned about the possibility of breaking the tabs (adjacent to the SAC springs) if I pushed any harder. On the bright side the SAC didn't appear to be adjusted all the way out, but it could be frozen in place for all I know.
However, the clutch disk was definitely loose; even with the pedal only pressed maybe half-way I could spin the disk in place with ease (transmission in 1st gear). The clutch disk marcel springs also appeared to be working just fine. There was nothing obviously wrong with anything that I could see.
Pilot bearing is a definite possibility. I mentioned in an earlier post that my 2001 S4's [original?] pilot bearing was toast, and as I recall it too had a slight lurching behavior in 1st gear prior to clutch replacement.
When I came back into the house after buttoning everything up I told my wife that my next move with the car will be clutch replacement. Yay! This is turning out to be an expensive month between my S4's water pump failing (effectively necessitating a full timing belt job) and now planning a clutch job (with all that entails including torque tube rebuild) for the Z06. At least I do all my own work...
I already have a replacement slave cylinder (stock-style, got it for a great price) and now need to buy a clutch. Heavily leaning toward LS7 clutch kit due to price point and since this car is mostly a daily driver on more-or-less stock power.
Will also have to pick out torque tube rebuild bearings and couplers.
The Corvette clutch is a diaphragm spring type pressure plate, much more complicated to troubleshoot than the old coil spring type us old geezers remember. It is easy to over match the hydraulic "throw" from the master to slave, and this is hard on the pressure plate diaphragm spring. Looking at the wear compensator diagram, it might be that over travel moves the wear compensator. There's nothing in the document that suggests that, though. You might also look at the tangential springs and see if they are bent. although that fact that the disc is free probably rules this out.
I think most if not all OEM clutches were LUK, at least the several I've swapped were. They are big in the OEM market, anyway, Usually with a Corvette, you find the pressure plate and flywheel have been overheated from poor driving habits. Other than that the biggest is clutch dust in the hydraulic system. Not much discussion about grenading, but there are people that could bust and anvil with a rubber hammer.
It's very possible there is overtravel and I need to reduce throw of the Tick Master Cylinder. BUT my current issue was present with all-stock hydraulics.
Looking for advice on replacing the rear main seal... for now there are zero oil leaks and in my other cars I've always skipped on the RMS during clutch jobs. BUT I'm contemplating the Sac City billet barbell, which necessitates rear cover removal. Should I just skip on both of those?
Popping the whole BH is a chore, a couple of the bolts are easier to get to from the top with the intake removed. When you go back together, be very mindful of the wire bundle that can easily get pinched
I'm actually looking at the whole cover replacement set (cover with seal installed and install tool, cover gasket, new bolts): Just ordered it, but doesn't mean I have to use it. Also it sounds like it's "good enough" to install this as-is without a separate tool (just the one it comes with) since the seal is already installed...
And I appreciate the advice on bell housing. On an old Audi A4 I had, I definitely pinched the starter wire harness between block and BH. That made for a fun first crank. Fortunately all was fine after adjusting the harness.
Yesterday the LUK LS7 clutch kit from RockAuto arrived. So far I have that, torque tube bearings, and torque tube rubber couplers. Also I have a Hinson polyurethane diff mount that I'm thinking to install.
Still waiting on the torque tube slinger, billet oil diverter barbell, and rear main seal + cover.
Also strongly considering ordering C6 Z06 diff clutch packs + belleville springs, and output shaft seals and side cover O-rings to refresh the LSD "while I'm in there". Have had some Mobil 1 LS diff fluid waiting to go in anyways. I think the bearings are all fine so don't have any plans to replace those...
