Multifunction switch-2001 base coupe?
Old Apr 8, 2020 | 03:24 PM
Clayton59's Avatar
Clayton59
Default Multifunction switch-2001 base coupe?
Is there a way to check the multifunction switch?
When I turn the light switch to the on position, the following happens:
No dash lights.
No outside lights... front, rear or side markers nor Fog lights with the except of High beam headlights (low beam do not work).
Cruise control works as it should.
Turn signals and brake lights work as they should.
Exception to the rule. When twilight is activated to the on setting, with the Multifunction Switch in the OFF position, I cover the windows and all the lights all work as they should. even switches between high and low beam headlights. Even the fog lights work as they should.
