CD player
Old Apr 13, 2020 | 07:33 PM
Vette rodder's Avatar
Vette rodder
Default CD player
My CD player in my 99 keeps getting stuck and reads err. I take the cd out and put it back in the cartridge and works fine then gets stuck again. Any solutions?
Old Apr 13, 2020 | 09:10 PM
strand rider's Avatar
strand rider
It might be wear on the belts or rubber parts due to use, but cleaning is the only thing I can suggest as something that might help. Sometimes a disk will get hung up and jam , but I never had that problem.
I was reading about a niche' rebuilder that wants everybody to mount the changer horizontally , I guess so it doesn't have to fight gravity as much in operation. I think this highlights the need for good condition of the mechanism . I have a spare CD holder from Panasonic that is interchangeable with the OEM unit , which is a rebadged pioneer changer, in case you need to buy parts, or decide your changer case is the problem.
My in dash player is worn to where I have to wait for heat expansion to get the thing to load properly, I guess it needs new rubber.
Old Apr 14, 2020 | 09:34 AM
Old School's Avatar
Old School
For my '03 I came across this site that has the CD unit for just $22 bux shipped! https://replacementradios.com/cd-dri...213438f26265c7 They might have a CD unit for a '99, you will have to match it up
This was for a brand new in dash CD unit, I had to disassemble the radio but that was easy to do, if you can remove the radio you can replace the CD unit.
Old Apr 15, 2020 | 09:51 PM
Clunk's Avatar
Clunk
This is awesome! I just bought a brand new-ish radio off another forum member for this reason, but I'm going to give this a try as well and may have a spare head unit. I recently did the aux-input mod but my head unit will not play CDs (err message even when tried 15+ times) so I cannot play my iPhone; I'm assuming it's an issue with the laser. The actual CD feeds and ejects fine.
I tried gently cleaning the laser with rubbing alcohol but there was no change.
Old Apr 17, 2020 | 03:58 PM
strand rider
thanks for the great resource, looks to be very useful. My used o3 came with a Sinatra cd in the dash player, I guess it was forgotten because of the difficulty in loading the thing. That it was a relaxing Sinatra cd and not thrash metal was a comfort to me.
Old Apr 18, 2020 | 01:07 PM
johnson-rod's Avatar
johnson-rod
It should have been a Beach Boys CD. I don't care if it never comes out.
To CD player
