Basically the whole time in the video it sounds like stumbling I haven’t got a video yet where it has been really bad but it has not been that bad since I swapped axles side to side so I got a pair coming in to swap out and I will see how that goes.
So obviously it only does it on acceleration?? If it was the axles i would thing it did it all the time. Waht happens when u decel in gear??
Decel nothing you can drive all the way to read line at half throttle and nothing I just changed passenger side axle and when I drove it and floored it in first it started to spin and go sideways and the car would never do that it just used to wheel like wheel hop and go straight and not really spin just hop so I am going to change driver side tomorrow and hopefully it goes away because randomly when I do drive it,its sometimes way better than before or got worse but this feels like the best its ever been.
Making head way thats all u can ask for. Not really u want it fixed.
So I got the axles in and somehow it just made a difference and is a lot better but I don’t know how it would just be better if it was a problem it should just fix it but I was able to dump the clutch and do a burnout no problem so I am convinced it is wheel hop but I don’t get why it would do it in 2nd or 3rd because the tires will never spin than
I finally have found out the problem I took fuses out of abs and tcm and the “wheel hop” went away so it is a problem with my abs ecbm which is another problem by its self but atleast I found the problem.
