Steele Brake Line Install Questions
Nov 23, 2002 | 10:15 AM
Hello all,
I have the Goodrich lines from LAPD.
1) Without any instructions can someone offer some guidance to installing the replacement retainer clips?
2)Also are there any problems with the lines touching suspension, rims or tires we should be aware of?
Thank you in advance.
Nov 23, 2002 | 10:24 AM
Cruise-In VII Veteran
Re: Steele Brake Line Install Questions (Kenny94945)
they go on exactly like the old ones come off.
They should not touch the rims, suspension , etc... you they do, you will have big problems! :eek:
:thumbs:
Nov 23, 2002 | 10:55 AM
I installed the linger lines up front as in the pic below. I never got any codes. If you can install them and then lower your car onto some ramps, Then turn the wheel side to side then check for line clearance.
[Modified by gmblack3, 10:57 AM 11/23/2002]
Nov 25, 2002 | 12:23 AM
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Re: Steele Brake Line Install Questions (gmblack3)
I'm curious why everyone installs the longer lines on the front when from the factory, the rears are longer???
Nov 25, 2002 | 01:02 AM
Re: Steele Brake Line Install Questions (nevrenuf)
That's the correct way to install them...if the front is too short....you will throw codes everytime you drive.
Nov 25, 2002 | 07:07 PM
Cruise-In V Veteran
St. Jude Donor '09
Re: Steele Brake Line Install Questions (HIGHRPM)
If the fronts are too short does it (pcm) sense too much pressure ,or greatly increased pressure??Just curious.Thanks. :cheers:
