C5 LS1/LS6 Coil pack harness
Old Apr 22, 2020 | 07:52 AM
Annie55's Avatar
Annie55
Cruising
Default C5 LS1/LS6 Coil pack harness
Good Morning Forum
I have a question concerning the coil pack harness that plugs into the coil packs.
i took mine apart because I bought a new stainless steel coil pack bracket. So in taking the factory wire harness apart from the stock bracket. I managed to mix up the harnesses.
I'm not sure which one is driver side and passenger side.
so my question to this forum does it matter which side I install the harnesses. Is this a idiot proof part. Lol help please
Old Apr 22, 2020 | 08:16 AM
StingrayRebel's Avatar
StingrayRebel
look at the coil plugs and each side will share similar wire colors, the ones you need to pay attention to will be light blue, dark green, red, and violet... on one side these wires will be solid and the other side will have a white stripe... the solid goes on the drivers side and white stripe goes on the passenger side
