Low Oil Pressure
Old Apr 22, 2020 | 11:46 PM
ZERRY 316's Avatar
ZERRY 316
Default Low Oil Pressure
What would cause intermittent low oil pressure? The pressure will go back to normal after running 2500RPM for a few miles. I thank you in advance.
Old Apr 23, 2020 | 12:16 AM
02general's Avatar
02general
I’d start by replacing your oil pressure sending unit, then go from there.
Old Apr 23, 2020 | 12:27 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
how many miles on the car
Old Apr 23, 2020 | 07:45 AM
oharal's Avatar
oharal
How much is "low?"
Old Apr 24, 2020 | 08:03 AM
Carolina99's Avatar
Carolina99
I'm assuming you've checked the oil level....Check the wiring and connection to the sensor.
Old Apr 24, 2020 | 08:55 AM
RichyB33's Avatar
RichyB33
What do you mean by low? The pressure will drop at idle versus driving as the pump is spinning slower. For instance, my car has 112,000 miles on it. At operating temps, it makes about 25psi at idle and 40-45 at 2000-2500 rpm on the highway. More information would be good.
To Low Oil Pressure
