are you talking about the spring pin that holds the linkage to the trans?... I don't see why you couldn't use something else that fits if you lost the original one
I found it and slapped it in a baggie. A baggie for every small part. A small part for every baggie. Lol. It is a cheap and effective way to organize nuts and bolts when you take an entire car apart. Now if I have any left over I know I screwed up big time!
I just used a spring pin form tractor supply when i reinstalled mine. I only replace it because I damaged mine when i removed it but i did reuse it last time with no issues.
