Wheel spacers?
Old Apr 28, 2020 | 12:02 AM
Daveinnola's Avatar
Daveinnola
Default Wheel spacers?
I bought a set of c6 zr1 replicas. The back ones fit perfect but the fronts seam a little tucked in. I would like to bring out 5 to 7mm. What is the thickest spacer I can run without changing studs.
Old Apr 28, 2020 | 06:43 AM
k24556's Avatar
k24556
about 3 mm is all. 5mm will require longer studs.
Old Apr 28, 2020 | 07:40 AM
scorpiofox69's Avatar
scorpiofox69
Running a 1/4 on my fronts. I would not push past this without going hub-centric (studs).
Old Apr 29, 2020 | 12:58 PM
Drice0217's Avatar
Drice0217
You could try weapon x motor sports.. get a 6mm spacer with extended lugs... That’s what I did
To Wheel spacers?
