speedo/odometer relation
Old Apr 30, 2020 | 09:20 AM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
Default speedo/odometer relation
I cant find a definitive answer. my car stopped registering MPH on both the cluster and the HUD. i started digging around and found a small toggle switch under the knee bolster. I tore apart half of the dashboard and removed the cluster to find that one of the previous owners had crudely tapped into the Vehicle speed sensor circuit and wired a switch in series with it. the wires came loose behind the cluster.
I removed the switch and soldered the wires back together the way the factory had it and now the speedometer(s) work again.
My question is: why would you want to switch off the speedometer and would this also disable the odometer when switched off? Btw my car is a 2003 coupe.
Old Apr 30, 2020 | 10:40 AM
wydopnthrtl's Avatar
wydopnthrtl
If it is the input to the speedo yes it could effect both.
My first thought was maybe a nitrous window / limiter input. But could be for turning off meter input for mile reading reasons.
Old Apr 30, 2020 | 01:20 PM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
i dont understand. can you please elaborate?
Old Apr 30, 2020 | 04:38 PM
GroundFlyer's Avatar
GroundFlyer
St. Jude Donor '19
To keep the mileage artificially lower than actual miles driven. For higher trade-in value maybe.
Old Apr 30, 2020 | 09:33 PM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
well the odometer only showed 10,156 when i bought it 3 weeks ago. i feel like even if that were so, that would be MANY miles to drive without knowing how fast you were going. ive been digging around the car and its definitely a low mileage car. the seats look great, there are NO scratches under the front fascia etc, etc. i guess ill never know, but i guess im not too worried either. oh, and it still shows an open recall for the infamous column lock malfunction.
Old May 1, 2020 | 01:36 AM
Blue Blood's Avatar
Blue Blood
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
Sounds like fraud in terms of miles driven. No other reason. How many owners before you?
Old May 1, 2020 | 05:37 AM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
3 owners before me
Old May 1, 2020 | 11:00 AM
GCG's Avatar
GCG
Originally Posted by 2003_Coupe
I cant find a definitive answer. My car stopped registering MPH on both the cluster and the HUD...
...My question is: why would you want to switch off the speedometer and would this also disable the odometer when switched off?...
Did you notice if the odometer stopped working when the speedometer was affected?
Old May 1, 2020 | 11:23 AM
mmartinez's Avatar
mmartinez
On older cars many people would simply disconnect the mechanical cable at the transmission or under the dash. With newer cars of course you have an electrical sensor that sends a signal to the cars speedometer/odometer, to my knowledge most cars only use one source to determine speed and miles driven.
Old May 1, 2020 | 01:03 PM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
GCG, unfortunately i didnt notice if the odometer was changing before i fixed it.
To speedo/odometer relation
