Suspension upgrade
Old May 1, 2020 | 10:06 PM
Thaddeus Snaith's Avatar
Thaddeus Snaith
Default Suspension upgrade
Any thoughts on this? I have contemplated upgrading my C5 Z06 with a Johnny Oconnell stage 1 (I think). It comes with the sway bars and a set of shocks tuned specifically for the set up. However, last I checked the price increased. I drive my car in Hpde and on the street.
Has anyone used a different set up?
Thanks,
Tad
Old May 2, 2020 | 10:48 AM
dskinsler83's Avatar
dskinsler83
Did you check with CCA, the vendor here?
Old May 2, 2020 | 12:53 PM
Thaddeus Snaith
I did not. Does CCA have a website?
Tad
Old May 2, 2020 | 04:25 PM
dskinsler83
https://www.corvettepartsandaccessories.com/
Old May 2, 2020 | 04:29 PM
dskinsler83
https://www.corvetteforum.com/forums...tte-parts.html
Chip is who I talked to and bought the very kit you are talking about about a year ago.
Old May 2, 2020 | 04:53 PM
Thaddeus Snaith
Default Thanks
Great. Thank you so much.
Old May 2, 2020 | 05:36 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Try VanSteel
Good luck
Old May 2, 2020 | 05:58 PM
Thaddeus Snaith
Default Thanks
Originally Posted by road pilot
Try VanSteel
Good luck
Thanks, I will check them out
Old May 5, 2020 | 08:14 PM
Duntov02's Avatar
Duntov02
8th Gear
If your car sees mostly street you might check out Koni FSD's. ride better than a bilstein on the street and made my car much more predictable.
I also installed a rear c6 z51 bar to help with the understeer. It still does on street tires but it's a lot closer to neutral. One track day at Thunderhill East on the bypass course
c5z06 rear sway 23.6
c6z51 25.6
sway bar can be bought from GM for pretty cheap
rear bar part # 10339124
bushing part # 15262795
I'd swap your endlinks if you haven't for the metal already
Old May 5, 2020 | 08:34 PM
Thaddeus Snaith
Default Thanks
c6z51 25.6
Thank you! Great info. You say swap endlinks for metal ones? Brand please?
Tad
Old May 5, 2020 | 10:41 PM
dskinsler83
Lots recommend Moog I have the ones that came with my Johnny O’Connel set up
To Suspension upgrade
