LS3 swaps into C5's
Old May 6, 2020 | 01:03 AM
svcjmo's Avatar
svcjmo
Default LS3 swaps into C5's
Just things I have learned and seen results on the Dyno with above swaps. Headers need to be 1 and 7/8. Ditch the 1.75 headers. Air Intake, Ditch the C5 stuff, go with LS3 style and blade MAF sensor. Huge gains when you swap out that tired LS1 or LS6.
Old Jun 12, 2020 | 08:23 PM
chase1873's Avatar
chase1873
What cable do you use to adapt the LS3 card style MAF sensor to the LS6 harness? I am having trouble finding the correct one.
Old Jun 12, 2020 | 08:27 PM
svcjmo's Avatar
svcjmo
I'm not sure what you mean by "card".
Old Jun 12, 2020 | 08:29 PM
chase1873's Avatar
chase1873
LS3 card style MAF sensor to stock LS1/LS6 harness
whoops, my brain shut off mid sentence.
Old Jun 12, 2020 | 08:35 PM
svcjmo's Avatar
svcjmo
These adapter harnesses are available from Racetronix, Casper Electronics, or Lingenfeltor. Or they should be unless this Covid thing has them backordered.
Old Jun 12, 2020 | 08:54 PM
chase1873's Avatar
chase1873
If you have a link to a specific cable that lets the LS3 MAF car style senor plug into the stock LS6 harness, that would be awesome.
I find it easy to locate the 97-00 MAF adapter, but not the 01-04.
I.e. all the adapters I find are for 5 wire to 3 wire or 3 wire + IAT breakout. None of these will work for me....
https://www.racetronix.biz/p/maf-ada...ire-gt/maf-001
http://www.casperselectronics.com/ca...product_id=377
https://www.michiganmotorsports.com/...r-lsx-ls-swap/
The other adapters are backwards and say "This harness allows you to run an LS2 style MAF on vehicles with an LS7 / LS3 style plug"
Amazon Amazon
Old Jun 12, 2020 | 09:01 PM
svcjmo's Avatar
svcjmo
C6 Corvette LS2 to LS3 or LS7 MAF Adapter Harness MAF0009 5 Pin to 5 Pin
by
MIDWEST CORVETTE MIDWEST CORVETTE
3.8 out of 5 stars
4 ratings 4 ratings
3 answered questions 3 answered questions
Price: $15.96 & javascript:void(0)
Your cost could be $5.96. Eligible customers get a $10 bonus when reloading $100. Your cost could be $5.96. Eligible customers get a $10 bonus when reloading $100.
  • Premium Made MAF Adapter Harness Allows the 05-07 LS2 Corvettes to Run the Later LS3 and LS7 Air Intake Systems.
  • MAF Adapter 5 Pin to 5 Pin.
  • This MAF Adapter Harness Will Fit other Vehicles. Please view the Detailed Pictures to be Sure this is the Correct Adapter for your Application.
  • Plug and Play.
  • GM Correct Harness Plug Ends.
See more product details See more product details
Compare with similar items Compare with similar items
$14.96 ">New (2) from <span style=$14.96 " /> $14.96 ">New (2) from $14.96
+ FREE Shipping
Report incorrect product information.
Old Jun 12, 2020 | 09:02 PM
chase1873's Avatar
chase1873
by MIDWEST CORVETTE
3.8 out of 5 stars 4 ratings
| 3 answered questions Price: $15.96 & FREE Returns Your cost could be $5.96. Eligible customers get a $10 bonus when reloading $100.
  • Plug and Play.
New (2) from $14.96 + FREE Shipping
I did see this, but wasnt sure a C6 LS2 05-07 harness would work on the 01-04 C5 LS6? Will it? That would be perfect.
Old Jun 12, 2020 | 09:04 PM
svcjmo's Avatar
svcjmo
Yep, Very same as C5.
Old Jun 12, 2020 | 09:05 PM
chase1873's Avatar
chase1873
Perfect. I appreciate the help.
Old Jun 12, 2020 | 09:06 PM
svcjmo's Avatar
svcjmo
Anytime!
Old Jun 14, 2020 | 12:00 AM
Blue Blood's Avatar
Blue Blood
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
Someone please enlighten me. What does the LS3/7 MAF do differently?
Old Jun 14, 2020 | 12:44 AM
svcjmo's Avatar
svcjmo
It does the same thing. However it is a blade style maf maybe 3/8 wide by 2.5 " long inserted into the air intake, thus no air restriction like conventional units contained within a fixed diameter unit. You can put this "Blade" into any size air intake unit. Of course, Tuning is required.
Old Jun 14, 2020 | 01:14 PM
Krusty84's Avatar
Krusty84
The LS3/LS7 MAF's IAT sample rate is also much higher so it is quicker to respond. It also doesn't suffer from nearly as much heat soak.
Watching IATs after swapping from a 85mm MAF to LS3 MAF, the temps drop as soon as the car starts to move. Gets back to ambient really quick after sitting at a stoplight.
Old Jun 15, 2020 | 09:53 AM
ArtClassShank's Avatar
ArtClassShank
What exactly are "huge gains"?
Old Jun 15, 2020 | 02:42 PM
Navy Blue 210's Avatar
Navy Blue 210
.5 liter/31" All Bore will add 25 -35 RWHP & 20-30 LB' throughout the Whole curve ~2500-6500 RPM 2002-2004 Z06 VS LS3 stock to stock. Changing Cam and Heads can multiply those gains even further.
Bigger Bore opens up many more head options.
Old Jun 2, 2026 | 06:43 PM
C5Trae's Avatar
C5Trae
1st Gear
Default LS3 in a 2000
So I was reading through this looking for advice on which long tubes people are running for their LS3 swapped c5s as im in the middle of this project. Does anyone have any advice on this ? Running 832 square port heads. And I know the exaughst side is a little bigger and a wider D shape than the standard LS1 heads. So just wondering if I can find a set of ls3 headers that will not have clearance issues on a c5. I was worried about clearance issues if I just ran c6 headers. Anyone have an answer ?
Old Jun 2, 2026 | 09:49 PM
svcjmo's Avatar
svcjmo
Just get a set of C5 1 7/8 headers. You may have to clearance the frame tabs a bit. No big deal!
To LS3 swaps into C5's
