Can't find parts
Old May 11, 2020 | 11:15 AM
Richard 53403's Avatar
Richard 53403
Cruising
Default Can't find parts
I have been chasing a few parts for about a year with no luck. I have a 99 C5 base mofel.
I need a Mass airflow Seal, part number 25099771
Discontinued None available in aftermarket..
I know that some aftermarket intake systems use a similar part but need to know which might be the correct size to fit the stock system.
I have a bad ABS module PN 10417038
also discontinued
I need to find a reliable rebuilder for this part.
the few I have contacted have said they do not have the parts to rebuild this unit.
I appreciate any help I can get.
This car is a daily driver.
Dick
Old May 11, 2020 | 11:25 AM
helga203's Avatar
helga203
also discontinued
Dick
this is what I'm afraid of with these cars. Can put u out of commission for a while Sorry can't help
Old May 11, 2020 | 12:01 PM
Bandit 00C5's Avatar
Bandit 00C5
2023 Corvette of the Year Finalist - Modified
2022 C5 of the Year Winner - Modified
For the EBCM/ABS module the part # does not have to match. The thing to look at is the letter on the module. It will either be a V active handling or M non-active. As long as you get one the same it will work. These modules were used 97-00. However, try to find 99-00 if possible.. This may help you find one sooner.
Old May 11, 2020 | 12:15 PM
Silver85's Avatar
Silver85
Is the ABS module throwing codes? If so which ones? There are a couple of sites claiming to be able to rebuild/repair the older modules but I haven't seen anyone in this group recommend them. They charge a premium and some of them can only cure certain ailments due to the board having been coated with a silicone type product when it was manufactured.
Old May 14, 2020 | 11:11 AM
voda1's Avatar
voda1
Give http://www.vettenuts.net/ a try for the seal.
Old May 14, 2020 | 06:50 PM
Billyjean9999's Avatar
Billyjean9999
You have to try junk yards. Vette nuts is one. Another is 20th street auto in Arizona.
Old May 15, 2020 | 10:41 AM
bc6152's Avatar
bc6152
Call the guys at www.contemporarycorvette.com
They have a load of wrecked Corvettes of each year. GOOD LUCK!
To Can't find parts
