High compression + bad battery + underdrive pullies = missfire???
Old Nov 24, 2002 | 09:36 PM
Phil97SVT's Avatar
Phil97SVT
Default High compression + bad battery + underdrive pullies = missfire???
Well since I installed my high compression heads, I have only been to the track once and had a bad nitrous explosion. Since than, my battery has gone south. The battery is not strong enough to even light up the interior lights with the keys in the ignition. I can jumpstart the car and get it running but it sounds alittle rough and lacks top end power. Could a bad battery and underdrive pullies not allow the ignition system to work correctly and give the spark plugs enough juice to light the 11.75:1 charge?
Phillip :thumbs:
Old Nov 24, 2002 | 10:18 PM
SFVetteman's Avatar
SFVetteman
Default Re: High compression + bad battery + underdrive pullies = missfire??? (Phil97SVT)
Low voltage inhibits the ability of the PCM to function properly. If you had an A4, you would notice that it's not shifting properly either.
Old Nov 24, 2002 | 11:22 PM
GDP's Avatar
GDP
Just get yourself an Optima Red Top and an MSD ignition with 8mm wires. That should take care of you. If not, throw in a better coil. I'm assuming that you have reprogrammed your computer already? Make sure it's all calibrated like it should be.
To High compression + bad battery + underdrive pullies = missfire???
