Parasitic battery draw
May 23, 2020 | 01:02 AM
5th Gear
What are the major causes for parasitic battery draw in a 1999 Corvette
May 23, 2020 | 06:35 AM
Quote:
Originally Posted by
Bizzyb65
https://www.corvetteforum.com/forums...post1592619382
How to locate drain sources on your car
May 23, 2020 | 08:27 AM
Vanity mirror can be an issue if the light doesn't doesn't cut off as well as glove box light
May 23, 2020 | 02:54 PM
5th Gear
bjones7131
thank you for the helpful Information.
May 23, 2020 | 04:37 PM
Mine turned out to be the passenger seat electronics...have not troubleshot it further.
May 23, 2020 | 09:03 PM
5th Gear
Appreciate the info
May 24, 2020 | 04:59 PM
Common causes of a battery drain are the seat switches. They have complex circuitry and if something fails in one of them the battery is dead in a day or two. I would make sure the battery is fully charged, pull both seat breakers then set up your multimeter on the 10 amps scale and see if there is still a drain. If there still is a drain, use the procedure in post #2 to locate.
May 25, 2020 | 01:28 AM
5th Gear
Appreciate the info.
