Need help with headlight
Old May 23, 2020 | 10:52 AM
C5.dro's Avatar
C5.dro
Default Need help with headlight
So I changed the gear because it was bad and I put the headlight back on but wen I turn my lights on the headlights goes down and vise versa honestly don’t know what I did wrong and when it goes “down” it doesn’t go fully down
Old May 25, 2020 | 12:48 PM
bighank's Avatar
bighank
Default Linkage might be on backwards
I did the same thing on the passenger side and reattached the linkage to the shaft but I did it 180 degrees backwards. Probably have to remove linkage and put it on 180 degrees from where you have it now. Look at the other side for guidence.
Old May 27, 2020 | 03:13 PM
Gunfighter77's Avatar
Gunfighter77
I agree. Sounds like you may have the linkage arm backwards.
To Need help with headlight
