1999 C5 abs removal.
Old May 25, 2020 | 01:09 PM
Montesa's Avatar
Montesa
3rd Gear
Default 1999 C5 abs removal.
OK, I give up. I need to check my EBCM and can't get it out. Removed the nut on the case but I can't figure out how in the world to get the two nuts off the ABS module so I can lift it off and remove the EBCM.
Any hints on how to do this? First time in my life I've ever been stumped getting a nut or bolt off.
Thank You.
Old May 25, 2020 | 07:08 PM
tabbruzz's Avatar
tabbruzz
Thank You.
there are you tube vids on how to remove it. I have not removed mine but have seen it done..worth a look
Old May 25, 2020 | 07:20 PM
Montesa's Avatar
Montesa
3rd Gear
Only thing I found was the later C5.
I think I need to find an extremely fine tooth 1/4" ratchet. There's only a couple of degrees you can rotate it.
Old May 26, 2020 | 12:36 AM
Montesa's Avatar
Montesa
3rd Gear
Finally got it. My friend had a trick universal that looked sort of like a CV joint. It works at extreme angles.
To 1999 C5 abs removal.
