Drivers Side Door Switch not working
Old May 26, 2020 | 11:44 PM
Thojoewen86's Avatar
Thojoewen86
Cruising
Default Drivers Side Door Switch not working
I have an 02 Z06 with a failed drivers side door control. I was out at an AutoX event last week and as I was packing up and ready for the long drive home, none of the controls worked on the driver side door. Windows, seat memory, locks, mirrors, all dead.
things I checked....
-fuses 33 and 34 are fine
-connection at the door to A Pilar, under the accordion, is solid
-key fob will only unlock or lock the passenger door
-the driver side door speaker Is working fine (does this rule out a connection at the door issue?)
-no signs of water issues anywhere.
-I’m tempted to just buy a new switch panel, but wanted to check in before dropping $150.00
any other thoughts I should look into!?
Old May 26, 2020 | 11:53 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
have you tried shaking that wiring harness and seeing if you get a change...I have read that you get wires rubbing the insulation off and you will get a short
you can find one on Ebay for far less than $150 if it comes to that
Old May 26, 2020 | 11:58 PM
Thojoewen86
Cruising
I’ve tried to shake the wires a few times with no luck.
i have another race this weekend and I need to get this wrapped up before then. Ebay might be too slow, but I might give it a shot
Open to all suggestions!
Old May 27, 2020 | 09:35 AM
Fast one's Avatar
Fast one
Take the door trim off and check for power at the module.
To Drivers Side Door Switch not working
