Rpms varies
Old May 28, 2020 | 06:56 PM
mrwick01's Avatar
mrwick01
Default Rpms varies
I have a 2000 and when pulling up to a stop the RPM's will drop off to about 400 which makes the car just short of stalling. After a couple of seconds the idle jumps up to normal by itself. If I am sitting at idle in neutral and tap the gas up to 1000 or 1500 the engine will actually stall as it comes down to idle. The MAF has been replaced but did help somewhat but did not cure the problem. If I just keep my foot on the gas pedal very lightly when coming to a stop and take my foot off after a couple of seconds all is well as far as the idle goes. Any ideas or fixes?
Old May 28, 2020 | 07:36 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Try cleaning your throttle body !!
Old May 29, 2020 | 05:42 PM
mrwick01's Avatar
mrwick01
Maybe a dumb question but how does a person go about cleaning the throttle body?
Old May 29, 2020 | 05:44 PM
C5 Diag's Avatar
C5 Diag
Here ya go !!...Brake Kleen and yes throttle body cleaner will work !!
Old May 31, 2020 | 03:08 PM
Big_George_S's Avatar
Big_George_S
The only dumb question here is the one you don't ask.
We all have different levels of experience and knowledge about these cars we are all here to help each other out.
Best of luck.
To Rpms varies
