Are X pipes typically the same?
Old May 31, 2020 | 02:02 PM
Dump_the_c1utch's Avatar
Dump_the_c1utch
4th Gear
Default Are X pipes typically the same?
Hi everyone. I have a 98 automatic vette. It came with a maganaflow axle back and magnaflow x pipe. I put the SLP loud mouth from my old 01 on it but I’m not feeling the sound with the x pipe!
ive noticed like the magnaflow X pipe the two banks are forced right into eachother and into a little chamber and come out as two but it seems like the borla x pipe they really Just are two pipes that meet. As they keep going.
is that enough you think to change the sound between the two?
also are all x pipes generally the same length? I “dislike” the magnaflow X pipe enough to buy the simple $250 borla and slip one off and the other on but anymore than that it can stay. I don’t hate it it’s just not my favorite.
Old May 31, 2020 | 05:38 PM
redzg's Avatar
redzg
Singing on to read responses. Might it be time for long tubes?
Old May 31, 2020 | 05:41 PM
Dump_the_c1utch
4th Gear
lol nah too much money invested in everything else in life this cars my beautiful turn key daily driver I just would like that H pipe snap back to it.
Old Jun 1, 2020 | 09:24 AM
turabo87's Avatar
turabo87
I've heard that the magnaflow x pipe is actually a better flowing and equalizing x than the majority out there.
Old Jun 1, 2020 | 09:50 AM
smitty2919's Avatar
smitty2919
IMO and from what I have gathered, the less angle the pipes have to each other when merging the better flowing X. The less bends/less severe bends in a exhaust the better flowing it is.
There IS a science to proper X pipes, but in a mass produced designs from the big companies this "ideal X pipe" design is not always done. Cross sectional area at the merge section, location of the crossover (X/H) also factors in for a PROPERLY designed system taking into account 1st/2nd/3rd harmonics.
For the C5 space is limited width wise in the tunnel as well as length front to back to place it. Kooks places the X up front, where majority of the companies place the X toward the back. Is one "better" than the other? I don't think anyone has tested it.
Long story short, for the sake of your needs simply getting a X pipe in the car...none of this really matters. I prefer the Corsa/Borla/Kooks x pipe design vs the "stamped steel" Magnaflow design.
Old Jun 1, 2020 | 10:05 AM
turabo87's Avatar
turabo87
That's also true about the less bends. Magnaflow X has more bends on the cross over, but it's just what I've heard. Regardless, I also like more the long X type that have almost no bend, for less restriction. But when you account exhaust scavenging harmonics like smitty said, this goes all out the window because the entire system is now responsible of the acoustic/harmonics of the exhaust scavenge. So we might never know unless you have a controlled parametric test. Smitty said it best, doesn't matter that much in the end.
Old Jun 1, 2020 | 10:47 AM
Dump_the_c1utch
4th Gear
my goal isn’t to get an X pipe in the car though. I already have the magnaflow in there. I don’t like it is what I’m getting at. No one seems to make a aftermarket H pipe so I’m wondering if the borla design is going to sound more like a H pipe than the magnaflow does.
Old Jun 1, 2020 | 11:57 AM
smitty2919's Avatar
smitty2919
Borla design will not sound more like an H. If you want an H pipe then you will need someone to custom make it. Or buy a "universal one" with the right dimensions to fit and have someone add it in place of the current X pipe.
Old Jun 1, 2020 | 12:33 PM
v6turbo87's Avatar
v6turbo87
Just an FYI, this is what the stock H pipe looks like cut apart.
Old Jun 1, 2020 | 12:40 PM
smitty2919's Avatar
smitty2919
I'll add this too from my car:
Stock manifolds/cats/Hpipe and GHL catback
Stock manifolds/cats/ custom x pipe and GHL catback
A proper H pipe may not sound too bad. H pipes get a bad reputation on C5's due to the small drilled hole creating that weird "flutter" sound everyone hates.
Old Jun 1, 2020 | 04:01 PM
lionelhutz's Avatar
lionelhutz
Why not find a stock unmolested mid-pipe and bolt it on?
Old Jun 1, 2020 | 10:49 PM
redzg's Avatar
redzg
Not everyone hates the H-pipe sound. I like the boat burble, running through the Corsa Indy cat back. Should I end up with long tubes at some point, I'll may have a proper H-pipe done, or I may stick with the stocker.
Goodness knows I ran quite a few sets of Heddman Headers in my youth, with straight 2&1/4 to 'turbo' mufflers and axle dumps. Sounded pretty fine on the Impala (65 SS 327) the Chevelle (68, 327 Powerslide) and the Nova (73, SS 350 hatchback!). The '73 C3 sounded fine with Hookers and 'turbo's, but with tips at the rear. No 'H's or 'X's on any of them -- of course, that was in the 70's and 80's...
Old Jun 1, 2020 | 10:53 PM
Dump_the_c1utch
4th Gear
been looking!! Can’t find one
Old Jun 2, 2020 | 10:50 AM
smitty2919's Avatar
smitty2919
A proper H pipe and the stock C5 H pipe is not the same...
Old Jun 5, 2020 | 01:44 AM
RC81's Avatar
RC81
Would we really know unless we dyno'd back to back? Can say all we want till we see proof. Course maybe someone has...
Old Jun 5, 2020 | 09:16 AM
smitty2919's Avatar
smitty2919
Dyno has nothing to do with it for this conversation. Stock H pipe has a small hole less than 1" diameter. A proper H pipe will have full diameter tube/hole connecting the banks.
The small hole is what makes the stock H pipe sound like crap. I'm not aware of someone replacing the stock H pipe with a true diameter cross over pipe since everyone simply goes to an X pipe. A C5 with a proper H pipe may not sound too bad.
Old Jun 5, 2020 | 10:42 AM
redzg's Avatar
redzg
It has been done: 'true' h pipe, x pipe, and duals:
https://www.dailymotion.com/video/x5s8nr8
Old Jun 5, 2020 | 11:57 AM
GCG's Avatar
GCG
This is consistent with the information on this Post (summary below) from the Thread "H-Pipe vs X-PIPE". That thread contains interesting information, relevant to what's discussed here.
Originally Posted by Evil-Twin
...The H pipe in a First gen C5 was the size of a dime not 2.5 inches... in 2000 they opened that cross pipe up to 1.250 in...
Old Jun 5, 2020 | 03:14 PM
smitty2919's Avatar
smitty2919
I'm skeptical about this "opening of the pipe" on later cars.
My 03Z I bought was a stock manifolds and midpipe without pre "pup cats" and has the smaller holes in the cross pipe... not like it matters now because it's long been removed from my car.
To Are X pipes typically the same?
