replacing front speed sensor
Old Jun 11, 2020 | 02:36 PM
pnewt's Avatar
pnewt
Default replacing front speed sensor
For those who have done it,how difficult is it to replace a front speed sensor on a 2004 Z06 ? does it require removing caliper and pads? Cant seem to find a youtube video that deals with the C5 specifically Thanks
Old Jun 11, 2020 | 07:22 PM
sjhanc's Avatar
sjhanc
I need a front sensor also, but I haven't been able to find a listing for the sensor by its self, only as part of the wheel bearing assembly.
Old Jun 11, 2020 | 08:00 PM
pnewt's Avatar
pnewt
I got mine from Advance auto, Oreilly also has them both are not stocked but available next day Hope that helps
Old Jun 12, 2020 | 07:52 AM
Moved to C5 Tech.
Old Jun 12, 2020 | 08:22 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Only comes as part of the hub assembly !!!
Old Jun 12, 2020 | 08:30 AM
C5 Diag's Avatar
C5 Diag
The hub assembly/wheel speed sensor removal not difficult if you have some mechanical abilities...hope this video helps !!
Old Jun 12, 2020 | 09:43 AM
pnewt's Avatar
pnewt
needed the harness Dealers can order 2 or 3 days if you need part number LMK I have it written somewhere
Old Jun 12, 2020 | 04:33 PM
1997 C5's Avatar
1997 C5
what was wrong with the harness ? did it throw code? what code?
Old Jun 12, 2020 | 08:53 PM
Bill Dearborn's Avatar
Bill Dearborn
Same code you get if the wheel bearing goes bad. Code tells you the area you need to look in but doesn't necessarily tell you the part that has to be replaced.
Bill
Old Jun 12, 2020 | 10:45 PM
pnewt's Avatar
pnewt
Default Hub
Thanks Bill. Ohmmeter should pinpoint where I hope
To replacing front speed sensor
