Instruments panel cluster board / ipc help needed
Old Jun 12, 2020 | 10:33 PM
Hugh Johnson's Avatar
Hugh Johnson
Default Instruments panel cluster board / ipc help needed
Has anyone experienced the dash panel buttons on both side of the speedometer go dead. None of them including the reset button works as well as the panel for the trunk and fog lights work. Has any one experienced the same and what did you do to fix it I was told the IPC board on back of the speedometer controls them and I didn't want to spend the money to find out that's not the problem. Your help would be appreciated
Old Jun 13, 2020 | 12:24 AM
ncali's Avatar
ncali
That is where you will find the problem and there are no parts available to repair the board. You will need to find a used instrument panel
Old Jun 15, 2020 | 02:22 PM
Hugh Johnson
Default C5 parts
I am beginning find that out that their are a lot of parts not available for the C5. It's funny I use to have a 29 Ford Model A roadster that I restored and their wasn't a single part I couldnt get for it and it was 80 years old.
Thanks ]
To Instruments panel cluster board / ipc help needed
