driver side blend door
Old Jun 12, 2020 | 11:12 PM
Mitch45's Avatar
Mitch45
Default driver side blend door
About a year ago I had to replace the blend door on the drivers side . Two weeks ago I had reason to disconnect the battery. The next time I drove it the AC would blow cold on the passenger side and hot on the driver side . Tried all the fixes , none worked . Today I pulled the actuator and opened it up . Everything looked fine . I plugged it in and when I cycled the AC I could see the actuator twitch but did not turn the gears . I went ahead and installed a new one still doesn't work . Tried all the fixes on this , same thing . Pulled that one and manually moved the door to AC .
Could it be the control module ? It is dual zone , the driver side temp **** turn but has no stop . The passenger side **** has a stop at full cold and full hot .
