ABS module question
Old Jun 18, 2020 | 06:10 PM
pnewt's Avatar
pnewt
Default ABS module question
How is the wiring routed from the ABS module down to the frame? I have replaced the harness from the frame and the wheel bearing on my 04 Z06 and it still shows 1233 code Open circuit probably means a cut wire and I want to tke it down and inspect Hope this makes sense. I am by no means an expert!!! Hope the module isnt bad
Old Jun 18, 2020 | 06:34 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
I’d test the signal and low reference wire (ground) as I mentioned to you in your other post and see what you have before tearing into this !!...if you have 5 volts on one wire and a good ground on the other your wiring is fine...just read across both wires and see if you have 5 volts...if you do the wiring is good !!
Old Jun 18, 2020 | 07:33 PM
pnewt's Avatar
pnewt
thank you
To ABS module question
