Scanners
Old Jun 29, 2020 | 03:40 PM
BLUDICE's Avatar
BLUDICE
Default Scanners
Will a DIY hand held scanner inform you of a vacuum leak?
Old Jun 29, 2020 | 03:48 PM
aaronc7's Avatar
aaronc7
A generic bluetooth OBD scanner from amazon with an app like Torque pro can give you a lot of the basics for really cheap.
Yes, you can monitor manifold pressure/vacuum, and fuel trims with that setup. I would expect to see high positive value long term fuel trims with a vacuum leak at idle.
Old Jun 29, 2020 | 04:34 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Yes, if you had a vacuum leak you will have elavated long term fuel trims...if you increase the RPM’s to 3000 RPM’s and long terms start decreasing you have a vacuum leak !!..video below !!...earlier this month didn’t you have some issues with idle ????
Old Jun 29, 2020 | 05:34 PM
BLUDICE's Avatar
BLUDICE
Mine is a Hyper Tough HT309 OBDII/EOBD
I’m not 100% sure I have an issue - it just seems to me to be a little high to me.
So I bought this thing when I had my ‘08 C6 and know enough to be extremely dangerous lol - so can I this thing pick up a vacuum leak or is this not “big” enough?
Old Jun 29, 2020 | 05:40 PM
C5 Diag's Avatar
C5 Diag
I am not familiar with this scan tool but if it can read fuel trims you’ll be OK...if your long terms are over +10 % you should be concerned !!...these scan tool are not dangerous !!
Old Jun 29, 2020 | 05:51 PM
BLUDICE's Avatar
BLUDICE
Sorry I’m lost of what you’re saying “fuel trims” & “long terms” - the car starts and runs great - bought it 3 weeks ago - has 37000 miles on it.
thanks.
Old Jun 29, 2020 | 05:58 PM
aaronc7's Avatar
aaronc7
Googled that thing real quick, manifold pressure, fuel trims are all "standard" SAE defined OBD params so I'm 99 percent sure that will work. Plug it in and see what LTFT is. Like he said, +/- 10 percent is a good place to be. If it is a bit off, it could be a vacuum leak, but it could also be something like a dirty MAF sensor. But at least with a scan tool it gives you some data so you know where to start if you have an issue (or maybe no issue at all).
Long term fuel trims means the car is adding or pulling a certain percentage of fuel. With a vacuum leak, air is entering the engine but not passing thru the MAF sensor.....so air entering the engine is greater than air measured entering the engine, so the computer is adding extra fuel vs what is measured to meet target air fuel ratio.
Old Jun 29, 2020 | 05:59 PM
C5 Diag's Avatar
C5 Diag
If you trying to diagnose this yourself educate yourself with these videos...if not a good shop should be able to handle it !!
To Scanners
