c5 headlight issue
Old Jul 6, 2020 | 09:25 AM
vanman18's Avatar
vanman18
Default c5 headlight issue
My '01 headlights come up fine when turned on but don't go down when turned off. I can turn the motors easily to put them down. Any suggestions?
Old Jul 6, 2020 | 09:51 AM
jjc508520's Avatar
jjc508520
One thing to try is to push forward for high beams then try and turn them off...
Old Jul 6, 2020 | 12:48 PM
vanman18's Avatar
vanman18
Will try, thanks.
Old Jul 6, 2020 | 01:07 PM
Old School's Avatar
Old School
Another thing to try - on each headlight there are four plastic bump stops, two for opening and two for closing. You can pull those off and turn them around 180 degrees. Over time the mechanism digs in to the stop. Flipping them gives it a new surface to stop against. Usually happens to the close stops though.
Old Jul 6, 2020 | 01:10 PM
Autoeng's Avatar
Autoeng
Do you have LED headlights? If you do, and they are like mine, you have to turn off the lights before turning off the car. The LED headlights don't draw enough voltage to activate the headlight close.
Old Jul 6, 2020 | 02:39 PM
UM Rebel's Avatar
UM Rebel
Check fuse #6 under passenger floor board.
Old Jul 6, 2020 | 03:35 PM
vanman18's Avatar
vanman18
Thanks, tried it 5 times and worked every time!
Old Jul 6, 2020 | 03:46 PM
Autoeng's Avatar
Autoeng
What did you try?
Old Jul 7, 2020 | 09:23 AM
vanman18's Avatar
vanman18
High beams before turning them off.
To c5 headlight issue
