Belt problems after Katech tensioner install.
Old Jul 14, 2020 | 03:24 PM
JBN's Avatar
JBN
Default Belt problems after Katech tensioner install.
Has anyone experienced excessive belt wear or stretching after installing a Katech serpentine belt tensioner? I torqued the tensioner to 25 ft/lbs. as recommend, but now I am on my third belt after two track weekends and the last belt only one day driving around town!
Any advice?
Thanks,
JBN
2002 C5 Z06
Old Jul 22, 2020 | 07:12 PM
JBN's Avatar
JBN
Default Belt Solution
If this would be of help to anyone, here is my solution below:
I called Katech and their tech guy said that he had not heard of this problem before, but he recommended going with the next sized shorter belt. I had been using a Gates K060802, so I checked the Gates online sizing chart and found the K060798 which is 2040 mm instead of the 2051 mm. Both have the same 20 mm diameter. I was able to tension the belt to the recommended 25 ft/lbs with the new belt. Tracked the car all weekend at NCM without issue, so that seems to be the fix I was looking for. Will just have to monitor to excessive wear, or tears. Hope this is of some help to anyone experiencing the same problem.
JBN
Old Jul 22, 2020 | 08:17 PM
aaronc7's Avatar
aaronc7
I haven't really seen issues with the stock one. Is this one auto or manual tensioning? Glad you got it sorted either way.
Old Jul 22, 2020 | 09:02 PM
JBN's Avatar
JBN
Manual tensioner made by Katech.
Old Jul 24, 2020 | 02:55 AM
Speedy007's Avatar
Speedy007
Make sure it spins freely .
Old Jul 24, 2020 | 01:15 PM
JBN's Avatar
JBN
I assume you mean the tensioner pully?
Old Jul 24, 2020 | 01:43 PM
Speedy007's Avatar
Speedy007
Mostly likely he is over tightening the belt . 1/2 inch of play split bxt up and down is about the best . 1/4 inch up and and 1/4 inch down and and should be fine just not so tight you got to use your muscles to move it .
To Belt problems after Katech tensioner install.
