f55 shock replacement
Old Jul 15, 2020 | 07:52 PM
timstl's Avatar
timstl
Default f55 shock replacement
Looking at 50th anniv vert with about 90K miles, I am guessing if original f55 shocks are still on I will need a replacement. I am hearing about 1700 for four
Old Jul 15, 2020 | 09:36 PM
timstl's Avatar
timstl
is there another mfg other than gm for these?
Old Jul 15, 2020 | 11:37 PM
My Vette Life's Avatar
My Vette Life
1700 is coilover cost
Old Jul 16, 2020 | 12:57 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
F-55 magnetic ride shocks are about $400 a piece on RockAuto. Ever since GM put in the b******* about no discounts, the price on these parts has gone up as well as all other OEM parts that GM sells.
Old Jul 16, 2020 | 01:37 PM
v6turbo87's Avatar
v6turbo87
There is no aftermarket source. The F55 option can be tuned out with a Tech 2 so you can install conventional shocks at fraction of the cost.
Old Jul 16, 2020 | 11:18 PM
Plasticman's Avatar
Plasticman
I used Bilstein Sports to replace mine, and frankly cannot tell the difference in ride and handling.
Note that I normally kept the F55 setting on the stiffer setting (Sport) before.
If you normally use the softer (Tour) setting, you might be better off with the softer HD Bilsteins (but that is only a guess).
Plasticman
To f55 shock replacement
