My rotors on my Z continually warp and GM will not fix them despite my best efforts. Anyway I am thinking of either the Eradispeeds or the Dilusi replacemetns (oem sizes). Any ideas on which one would be best? The Dilusi's are a bit more money but still within my budget.
Thanks,
Joe
I have heard good things about both of those rotors. The ERadispeeds come with an anti warp warranty I believe. I went with rotors done by Porterfield...they take stock rotors, Heat Treat them, And cross drill them price is $140 per rotor. I have yet to put them on the car and I have never had warped rotors on this car (25,000 miles). But I will let the forum know how they work when they are on the car. Good luck with your decision. :cheers:
Read the post by Skyguy "Warped rotors and other brake myths"...it seems that rotors do not warp, pad material builds up on the surface causing the pulsing you feel. http://<a href="http://www.stoptech....s_myth.htm</a> :cheers:
I would guess that 90% of "warped" rotors are due to improperly torqued lug nuts, or to the brake pad build-up mentioned. Sand the rotors and do a brake pad "seasoning" routine to check it on your car. :)
Re: Need new brakes....any advice?? (carpe dm)
"I would guess that 90% of "warped" rotors are due to improperly torqued lug nuts, or to the brake pad build-up mentioned. Sand the rotors and do a brake pad "seasoning" routine to check it on your car. "
I like the Eradispeeds for street and occasional track events. They work great and look very cool.
If you are going to get into Track events in a big way, I would go with "The Brake Man". Their convoluted rotors are outragious. We have had excelent luck with them on ALS cars as well as quite a few sprint cars.
