rear end whine
Old Jul 20, 2020 | 11:24 AM
threepeat's Avatar
threepeat
6th Gear
Default rear end whine
getting a high pitch whine out of rear end starting at 50mph. new tires after this started. any ideas?
Old Jul 20, 2020 | 11:32 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
When does it happen? On acceleration? On decel? Both?
Old Jul 20, 2020 | 03:47 PM
threepeat's Avatar
threepeat
6th Gear
does not seem to matter. once you hit 50 - it whines no matter what. thanks for the reply.
Old Jul 21, 2020 | 05:10 AM
Moved to C5 Tech.
Old Jul 21, 2020 | 10:32 AM
oharal's Avatar
oharal
The usual C5 diff failure. The Bellville washer (or washers) snaps and stop pushing on the clutches and when everything loosens up the clearances in the ring and pinion are wrong and it makes it whine and start wearing out. The only fix is a rebuild. I'm coming up on my 3rd diff but this time I'll be getting an RPM built one with improved bellville washers so I don't have to go through it again. If you ask RPM they'll tell you a diff with 50k miles is on borrowed time. Hard use seems to make them get louder faster in my experience with 2 failed units.
Old Jul 21, 2020 | 10:35 AM
Stingroo's Avatar
Stingroo
Sounds like it, yeah.
If you do a burnout and notice your skidmarks have little skips in them - bellville washers are toast.
To rear end whine
