Front flasher issue
Old Jul 25, 2020 | 09:26 PM
JimboC5's Avatar
JimboC5
4th Gear
Default Front flasher issue
It’s a 2001 corvette. Right front flasher burned out (literally melted the housing) I replaced the bulb and it works BUT my right turn signal is still flashing rapidly. I cycled the hazards a few times and they function normally. What could be the issue?
Old Jul 25, 2020 | 09:27 PM
JimboC5's Avatar
JimboC5
4th Gear
Old Jul 26, 2020 | 10:07 AM
Silver85's Avatar
Silver85
Did you replace the bulb with an LED or bulb that draws less current? I believe the circuit detects less current draw and assumes a bulb is out which causes it to go into hyper flash mode.
Old Jul 26, 2020 | 03:10 PM
JimboC5's Avatar
JimboC5
4th Gear
I replaced exactly what it had a sylvania 4157. Thinking it could be the bulb socket itself which is relatively cheap and easy to do but I’m afraid that’s just wishful thinking on my end
Old Jul 26, 2020 | 07:05 PM
Silver85's Avatar
Silver85
Are the Daytime Running lights working? I know it’s a two element bulb. Maybe that part is causing the blinker to hyper flash?
The sockets are easy to change and do get brittle and break over time. Very possible that is the problem.
Old Jul 27, 2020 | 02:20 AM
JimboC5's Avatar
JimboC5
4th Gear
the rest of the lights work perfectly fine. What’s the procedure for the socket? Kind of hard to see in there but I should be able to do it with the headlight shroud removed.
Old Jul 27, 2020 | 02:31 AM
Speedy007's Avatar
Speedy007
Perfectly normal as the bulbs are hot the melt the housings over time . Suggestions switch to a led .
To Front flasher issue
