Slow Get power after launch
Old Jul 30, 2020 | 02:59 PM
Ryukin's Avatar
Ryukin
Default Slow Get power after launch
Ive noticed that when I fully let off of the clutch and I’ve just started to roll at slow speeds, if I give it some gas it’ll take a full second for the car to actually move with the power it should. I’ve noticed this when trying to do donuts (with traction control off obviously). I’ll mash the gas down and it’ll go a little bit but then a second later the wheels will start spinning as they should. It feels like the car has turbo lag when trying to do anything off of a launch.
does anybody know what this could be? I’m sure it’s not normal.
Old Jul 30, 2020 | 04:00 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Maybe TPS sensor...hard to say !!
Old Jul 30, 2020 | 04:45 PM
Silver85's Avatar
Silver85
Could your clutch be slipping? Do the RPMs match the speed of the car or are they elevated and the wheels catch up to it slowly?
Old Jul 30, 2020 | 05:44 PM
Ryukin's Avatar
Ryukin
it doesn’t seem like the clutch is slipping. This only happens from a launch every other gear is responsive
Old Jul 30, 2020 | 07:01 PM
heggsc5's Avatar
heggsc5
Sounds like you're either bogging it or the TC is still activating. If you feel it bite, then it shuts down for a second, that's probably TC. If it feels like a hiccup/hesitation, could be a "tune up" issue. If you're just too low in the powerband, you're not making enough power.
Old Jul 31, 2020 | 12:36 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
This is all correctable with proper tuning Not a handheld but with HP or EFILIVE
YES there is a built in 1-3 second delay to "power enrichment" meaning when you floor the throttle there is a 1-3 second delay from P/T fueling to PE
ALSO there are other tuning parameters that aid in getting full throttle when you floor it
The other most important table for a drive by wire T Body is the "ETC Pedal TQ Reduction Table"
This table prevents the T Body to actually go to 100% WOT until you reach approx 3600 RPM's--Even if you have the throttle floored you think Its WOT but actually it is just barely cracked open--Then you hit about 3400-3600 and finally it comes alive and goes to 100% WOT
A real tune -- even a mail order tuner can get rid of all these delays and get you full power
To Slow Get power after launch
