Speedometer issues
Old Aug 2, 2020 | 06:11 PM
rhill1234's Avatar
rhill1234
3rd Gear
Default Speedometer issues
I have a 2001 C5. The speedo will not register and the HUD shows zeo. The cruise works and DIC displays cruise speed. I had the speedo cluster out to work on HVAC actuator and this started after. I have checked the plug to be sure it is installed all the way. I have also cleaned the grounds in the engine bay. When I start the car the needle moves thru its range so the speedo motor is working. Any ideas?
Old Aug 2, 2020 | 06:14 PM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
Wheel speed sensors?
I think the transmission has one too
Old Aug 2, 2020 | 06:26 PM
SilverC54me's Avatar
SilverC54me
The DIC display gets the speed for cruise control from the serial data bus. The speedometer/HUD get this info from a discrete wire that comes from the PCM to the IPC. Pin A7 on the IPC connector has the VSS signal (Speedometer). Check for damage to that wire from the connector down the harness. In the 2002 service manual this is a Green wire with a White tracer.
With the description of the work you did before this quit working I would say the break in this wire is within 12 inches of the IPC connector. It is possible that the wire is broken with in the connector.
Gary
Old Aug 2, 2020 | 07:20 PM
rhill1234's Avatar
rhill1234
3rd Gear
Thanks. That was the only thing left I could think of. I'll start tracing the wire and see if i possibly damaged it.
Old Aug 5, 2020 | 09:19 PM
rhill1234's Avatar
rhill1234
3rd Gear
So I ohmed out the wire could not find any breaks. I was pulling the speedometer apart to examine the circuit board and noticed the plugin on top of the speedo for the HUD had 1 prong pushed over against the other on the far right. I separated them plugged in the speedometer and it worked., Reassembled everything and now speedometer and HUD work fine. I must have pushed the prong when I plugged in the HUD the first time I reassembled after working on the AC actuator.
To Speedometer issues
