2001 electrical problem
Old Aug 7, 2020 | 11:02 AM
bma2's Avatar
bma2
Default 2001 electrical problem
My first problem with my 2001 Z06.
Car is maintained on trickle charger in HVAC controlled garage.
Battery is 1 year old.
1 month ago tried to start car. When key is fully turned, dash lights up appropriately, but no engagement of starter motor. No click indicating low battery, just complete silence!
I returned car to tricker and couldn't come back to it for a week. Upon return, started perfectly with strong battery spin of starter.
Everything fine for a month.
Yesterday, same issue.
Then after pulling key out and re-trying a few times, works perfectly!
My garage gurus say it will be impossible to find the problem if its not manifesting itself.
But of course when it does occur---I have no way of getting the car to them.
So who knows what the problem is or where to start looking.
Old Aug 7, 2020 | 06:21 PM
1KLRTOY's Avatar
1KLRTOY
First thing I'd look at is the ignition switch and burned contacts
Old Aug 7, 2020 | 06:42 PM
Moved to C5 Tech.
Old Aug 8, 2020 | 08:42 AM
v6turbo87's Avatar
v6turbo87
No engagement of the starter motor/no click does NOT necessarily indicate a low battery. The only way to know if the battery is an issue is to measure the voltage with meter or have it load tested. The problem could be VATS related or a bad/failing theft deterrent relay. The first thing I would try is a different key and clean the pellet on any key you are trying. The contacts inside of the key tumbler can get dirty/intermittent and not make good contact with the key pellet. Yes the ignition switch could be bad as well but there are other thing to look at before replacing it.
Old Aug 8, 2020 | 09:50 AM
mmartinez's Avatar
mmartinez
As stated it could be your ignition switch contacts, or it could be the VATS key reader that is part of the ignition switch cylinder. Observe what the Security light is doing when the car fails to crank over, it should be off, if it is off then yes most likely the problem is the ignition switch contact block.
To 2001 electrical problem
