Fuel injector identification.. Help!
Old Nov 30, 2002 | 09:22 AM
Dan Parker '96's Avatar
Dan Parker '96
Default Fuel injector identification.. Help!
I picked up a set of fuel injectors on Ebay recently. The seller claimed they were new 2002 LS1/LS6 fuel injectors. I just received the parts and they do look brand new. But the problem is with the part number. It's not coming up as a stock '02 LS1/LS6 (they use the same injector that year). But I swear I've seen this number, vividly, during my injector research as a GM part number.
Here's the part number off the injector (it's a GM part number): 12555894
Apparently this injector is a Bosch unit. Here's the manufacturers ID: 0 280 155 890.
If anyone can help me identify these suckers please let me know. I've got a known good set of LT4 injectors headed my way (courtesy of a forum member) but would like to ID these others so I can either use, return, or resell 'em.
Old Nov 30, 2002 | 09:35 AM
Av8ter's Avatar
Av8ter
Default Re: Fuel injector identification.. Help! (Dan Parker '96)
I just sold my 02 LS6 injectors on ebay as well. The numbers on the side of my injectors are 12561462 on one side, the other side the number is 0 280 155 931. If you go to the site below my numbers dont even come up. I guess you will have to call a dealership or something and see what numbers they give you to compare with. The numbers that do come up in the site above are 12482704. But like i said, they didnt even list my numbers.
g m parts direct dot com
damn website
[Modified by Av8ter, 8:43 AM 11/30/2002]
Old Nov 30, 2002 | 07:03 PM
Dan Parker '96
Default Re: Fuel injector identification.. Help! (Av8ter)
Thanks for the reply. I figured I'd have to go to a dealership. Appreciate the effort though.
To Fuel injector identification.. Help!
